Stroked
- Dec 26, 2011
- Beloit, Kansas
- Jared
- K10
Well I attempted to change my turn signal switch today and failed miserably.
I got everything taken apart and unplugged the harness under the dash, but couldn't get the harness to pull up through the steering column. Best I can tell, there is some sort of sleeve that the wires all run in up through the column. It's just barely big enough for the wires to fit through and there's no way I could ever get the plug through it.
You can see the end of the plastic sleeve here
I spent 10 minutes just getting the wires to slide up and down a little in the column and 2 hours trying to figure out a way to pull them out without cutting the plug off. I even took the column bolts out thinking that was squeezing the plastic sleeve. Every write up and Youtube video I've looked at has just shown the harness just pulling up through the column with ease. Am I completely stupid and missing something here or is everyone else's column different?
I gave up and put it all back together for now.
