Tranny
andrewrodgers1992
US
andrew
Can you take a 4l60e and use parts to rebuild a 700r4
Sent from my LGMP260 using Tapatalk
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The clutches and band interchange, most of the piston seals are the same, the case, pump, valve body, won’t work. There are lots of other little things that are different. According to the ATSG book, there are pump/reverse input housings, and pistons that aren’t compatible. If your serious about trying to overhaul your trans, you would be time and money ahead buying the correct overhaul kit. If you want to use the hard parts you need to closely inspect the parts, and probably do some research to ensure the parts fit
andrewrodgers1992
US
andrew
[emoji38]
I don't see what's so funny I dont know much but have much heart and love for it and willin to learn can go wrong by asking questions
roundhouse
atlanta ga
justin
77,78,79,80 ?
You should find someone local who has experience doing it and buy em lunch and ask for tips
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Not laughing at you. I was laughing at the dream tranny pic that rusty posted. I hope you get your transmission rebuilt. Good luck.
xXmutantXx
