Torque converter
bigge31566
GA
Ervin
I am installing a 350 with about 400hp in a 1983 C10 and also a 700R4 tansmission thats been beefed up with shift kit, the question I got its got a 3000 stall converter, would that be too much for a everyday driver who might just want to step on it every now and then
Driver4r
Nebraska
Trevor
k10,c20
Gears?????
And whats your cam profile?
hirschdalechevy
norcal
rich
k-30
Gears?????
A must know , and it also depends on which kind of converter brand you go with , a 3000 b&m or tci are loose converter's and are not super street friendly , (I do not like them). If you call up turbo action or continetal they will build you a tight converter for your cam , gear , wieght combo that will be very street friendly and only stall at 3000 rpm , (or whatever stall they pick for your combo) when flashed. These converter's are expensive , but they are worth every penny IMO .
:waytogo::waytogo::waytogo:
tanz45
Hopewell, PA
Don't skimp on the verter either if you restall.
There is a reason good converters cost more.
dmcelhan
