Switching from mechanical to electrical gauges
Sam414
Gibsonia PA
Sam
First time posting here. I have a 77 k20 that I am working on. The gauge cluster was damaged and the temp gauge had been replaced with an after market mechanical gauge. I bought a replacement cluster from, I am guessing a 78 or 79 which has an electrical oil gauge. My 77 had a mechanical oil gauge. I was wondering if I change the oil pressure sender from mechanical to electrical and wire directly to the gauge in the cluster if that would work or will I have issues. Thanks in advance.
87scotty
Central il
Andrew
V20
5.7 for now
If sender and cluster are the same year ya itll ne fine
You just want to be sure that the range of the sender matches the range of the indicator.
That should be a 0 -60 psi sender. It will be stamped on one of the flats of the mounting nipple:
djisurfli
