Suggestions for replacing this?
Dleslie212
Phoenix
Dustin
5.7L 350
I've read that these aren't made anymore. This is the sleeve for the body mount bushing on the passenger floor. All the others were in decent enough shape that I cleaned them up, painted and reused.
Anybody know where to get a replacement?
Easy to make,use appropriate size hole saw cut a disc out of flat stock,cut a short piece of dom,drill the hole in your disc to fit your bolt. Weld,braze or just let it float its captured .
Dleslie212
Phoenix
Dustin
5.7L 350
Float its captured, meaning just let them rest together without welding them together?
Bennyt
Surprise
Ben
Looks like you are in Phoenix, I'm on the westside. I have a couple of buckets of old parts. As soon as the sun goes down a bit, I'll dump them out and see if I saved any.
Dleslie212
Phoenix
Dustin
5.7L 350
That'd be badass thank you
Bennyt
Surprise
Ben
Ok, not in my shed. I have a few other bins to dig through. I can do that Tuesday. I also am about to install poly bushings on my C30 later this week. If those are the same you are welcome to them as well.
Dleslie212
Phoenix
Dustin
5.7L 350
That's what I'm doing is poly bushings on my k10.
Thank you for looking - don't go overboard searching or anything, I appreciate the effort you've already spent
Dleslie212
Phoenix
Dustin
5.7L 350
Dleslie212
Phoenix
Dustin
5.7L 350
Who here has done the Energy Suspensions body mount bushings? Im looking at the diagram and it shows the cone shaped bushings on top, with the smaller end of the cone facing into the bushing sleeve. It just doesn't seem right. Can anyone confirm proper orientation?
Dleslie212
Phoenix
Dustin
5.7L 350
Carb'ed Vortec 350
Does a shop manual show it?
legopnuematic
Licensed Junk Dealer
MO
Spencer
The cone goes on the bottom, small end facing the ground.
workinman789
