Start wires question
Nick Boomershine
Kansas
Nick
I have a 77 c20 454. Change the starter on it and noticed the purple wire that goes to the ignition I beleave was cracked and had tape around it.
Question is what gage wire is that purple wire my wiring diagram don't say and I want to fix the wire.
Thanks for the help
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
It’s probably a 12 gauge wire.
AKguy
Alaska
Randy
K30 Crew Cab Silverado
12 on mine.
Nick Boomershine
Kansas
Nick
That's what I was thinking it was just wanted to check.
Thanks guys
If you replace it, you need to find automotive wire that meets SXL specs (best choice) or GXL specs for engine compartments. The insulation on wire from Autozone and other box stores will not hold up when exposed to exhaust and engine heat.
Thank you for your wisdom Bruce
Keith Patton
Keith
I'm in the process of same issue.. that tail piece with no insulation is a fusable link, per wiring diagrams is.. 14guage on the 10Guage Red wire, and the other wire you show in the picture insulation gone, is a 20Guage fusible link.. the 14G is pretty easy to find with the right eyelet, the 20G you will probably have to order, I found a small roll of it at Napa.
so both of those wires had a fusible link from the factory, that connects to the starter.
VFL1982
