Speedometer Cable Discovery!
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
I had the same problems as you all did, bouncy speedo, I changed out the junker thinking it was broken in some fashion but it wasn't. I too put an AC Delco speedo cable and now speedo works like it should. Made in Mexico but at least it's on the same continent!:dancingpoop:
I take the 'Made in Mexico' as a good sign too. Probably still from OEM production.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I honestly prefer Mexico to anywhere else besides here and Canada. The third brake light on my Caprice was made in Spain, though, and I’ve seen aftermarket parts made in Israel so I feel good about those, too.
crpntr78
Missouri
Yep, almost anywhere but China!!
highdesertrange
kalifornia
mike
k30
as a note the cables with the knurled nuts at both ends are for cruise control.
note #2 if the cable doesn't want to click into the speedo, unscrew the end at the trans/transfer case. this allows the cable to move a little so it goes together easier. when you go to reconnect the other end you can twist the cable with needle nose a little if it doesn't line up right.
highdesertranger
fastwagonfab
