Some 8 lug axles from a 1984 Chevy 3/4 ton truck
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
Not sure if these are special or not, “big hub”.
anyhow
When I get some more time off work I’m planning on hitting them up with some pool sand then hose them down with a bit to f black rattle can.
At that point pull the diff covers and have a look as to what ratio is labeled in the ring gear.
The pinion seal on the rear diff is already leaking a bit so that will have to be addressed as well.
Lots of work to do and plenty of motivation just lacking the time off of work.
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
looks like a d60 front and a d70 rear, 1 ton. that's the good stuff.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
That's Incredibly small knuckles on that front to be a 60.
Not to mention, Chevrolet 60 would be kingpin. Not balljoint.
Front is a 10 bolt.
For the rear, a dana housing casting wouldn't have that kinda web. That's a 14b semi float. There is no full floating hub on the outside.
Vbb199
Salisbury NC
Vince
Show pics of covers to confirm
Vbb199
Salisbury NC
Vince
anyhow
Show us what they're going under! :D
TubeTruck
East TN
Denis
Suburban K10
LQ9
Yup, 14 bolt Semi Float and 10 bolt front. I'm building a 10 bolt for my truck also. Just take your time and do everything right. You don' want to get them together and get them in only to have to tear into them.
On a Side note I wouldn't use pool sand. Silica is VERY bad to breath in. Check your local hardware store. I buy recycled coal slag called Black Blast for $8 a bag and used a Harbor Freight 110lb blaster. Put 2 bags in and went through about 1/2 the tank for both axles.
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
Thank you tube truck.
Will be picking up some black blast.
Typically I’m pretty cautious and always dawn out with full respirator, but will take your advice and pick up some black blast.
thank you
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
Will post some diff cover pics as soon as I get home.
will be putting these under a 1986 suburban.
Craig 85
Nashville, TN
454/TH-400/NP205
Your other parts truck had the Dana 44 with the large hubs. It probably also has a full float 14 bolt in the rear. This axle does have the correct parking brake cables for the Suburban though.
RoryH19
Rory
R10 Silverado SWB
I think I saw these on CL the other day for $2500
Just checked and the post was deleted.
RoryH19
Rory
R10 Silverado SWB
imyourhuckberry
