Scores from DIY Parts Yards, Pull A Part, U Pull It etc
Carb'ed Vortec 350
I didnt see a date around the bell casting , just the 3970010 on the lower flat of the bell casting,
And "C 1244" on passenger side upper flat around the bell.
The stamped number on the front was like, V00xxxxx
Cant remember
What are your plans for the 2bbl?
Carb'ed Vortec 350
The actual carb?
Trash can.
Unless someone has a use for it , then i might be a capitalist dick
(Kidding)
Is it in decent condition? Does it still have the tag on it? I am considering a Dual Jet for my 292.
Supporting Member Army
Cant remember
Killing me man... That C number is in fact the casting date code. I doubt it is 1244... C means March, 12 would be the day of the month and the 44 would mean 1944(which is obviously not possible). The entire stamped number at the front would give you the assembly date and a partial VIN at least. It would be highly beneficial to figuring out this engine if you take some pics(this lines for you @Rusty Nail ) of the casting numbers and the stamped number on the front pad. As to what it was rebuilt to, there really isn't any telling. That company no longer exists, but it appears they were a simple stock rebuild type company.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
After giving it a look again today, no alcohol and scratched down numbers on paper
This is a 75 350 block from a 20/30 series truck, presumably since the trans had 1380ish yokes, it was a 1 ton drive train.
In stock form it made a unimpressive 160 hp, but it has been rebuilt at some point in its life and now posseses a 327 intake
I looked again at the thin, barely legible pad on the front and it was v1002txr, txr is suffix for 75 350.with a 4 barrel carb
So now moving on, why does it have a 2 barrel and 327 intake?
I was spot on the money when i first laid eyes on it and saw the exhaust manifolds , i said "those look like early to later 70's manifolds"
Yep. Its a 1975 350.
Now i REALLY wanna pull the pan and see if its got a 327 small journal crank in it, possibly was rebirthed as a 383?
Probably not with a 2 barrel.
this is just another generic 350 that i have no use for.
Vbb199
Salisbury NC
Vince
Might i also add, under a second look at thosr brackets, thats 70s **** too.
What a total waste of everyones time.
Vbb199
Salisbury NC
Vince
Nah, you never know until you dig around.
I reckon thats true.
I never gave it an intense gander just while it sat on the trailer.
Fun anyways, id like to still know what heads and crank its got.
Carb'ed Vortec 350
Soon we will all know. I was hoping it was a 327, that would have been cool.
Vbb199
Salisbury NC
Vince
Maybe if theres time after work ill pop a valve cover and get a p/n on the heads.
Vbb199
Salisbury NC
Vince
A good small block is a good small block, imho.
Well if it turns out the heads are a dud, it can be yours for the low payment of free lol, because otherwise its going to the scrap yard
Didnt mean for that to sound smartassy, i just mean i have no use for it rn
Moderator
If it's reasonably clean inside and not trashed, it's got a little more value than scrap weight. And if someone buys it, you don't have to haul it off, lol.
Johns C10 Hubcap
