Removing Front Coils
GOBR
Memphis
Well tomorrow Im gonna try to drop the front end if I can find a jack. I had it all apart last time but I couldnt get the upper ball joint to seperate. I was gonna take the u bolts off of the control arm but it seems easier this way.
Now for 2nd question. Should I start at cuttin off 1 coil or go straight to 1 1/2 or stop in the middle and do 1 1/4? I really only wanna take em out once.... The rear only has 2 leafs I beleive and sits 3 or 4 inches lower than the front.
J Knight
Baytown TX
82 Chevy
350ci
To remove the spring you unbolt the lower ball joint NOT the upper ball joint, and tou can use the springs tension to do it just leave the castle nut on to break it loose for safety.
I would only cut one round off the front springs to start, sometimes removing them twice is the nature of the beast when lowering.
GOBR
Memphis
Yeah I learned bout cuttin too much on one of my fox bodys. Cool deal.
sallyjeank10
