Rebuilt 5.7 TBI shopping talk...
Where is the best deal on a rebuilt motor? My mechanic said to stay away from Jasper motors. Anybody here done any reasearch or have any input? Just figuring my options. Buy local or online? That would involve truck frieght I imagine. What about engine core chrages? Help?
davbell22602
Bunker Hill, WV
I Dont
Have
One
Jasper is junk in GM products. Crate is good in GM products. Jasper is good in fords though. Get a crate vortec block and re use all the external parts.
Vortec will bolt up to my truck? :think:
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Or you could find a TBI truck with a bad trans and good engine, that way you can hear it running.
That Blazer I almost bought at the scrapyard, he wants $600 for that motor.
Swims350
Logan WV
none
I would find one local unless you got the coin to drop for a new one.
My old man hates jasper too. he got a trans from them, and was going to get a 455hd or whatever it is for his trans am. he got the trans and it sucked, he said he wanted it built and to be right, and it was basically stock, called tech support, guy told him to take a rod out and cut it off 1/4 at a time to get what he wanted, dad said time he was done it would shift into 3rd before he got out of the garage, so he said I'm sending it back. Guy said you can't you modified it, dad replied to the guy with you told me to do it, guy said nope can't return. Dad laughed and said I'll stop the PO on it. So then the guy was like oh, ok then send it back.
what about getting a short block? have the heads redone local, or yourself they are pretty easy except for the valve job.
I guess I'll just go with a local used one and keep this motor for a rebuild project. I bought a 4.3 rebuilt motor from Pep Boys for my old Carpice and it had a oil galley plug missing, so I had to pull it back out and exchange it.
Vortec is not a direct swap, you need a special intake manifold that will bolt to the heads. You also need additional parts and some exhaust modifications to keep a functioning EGR valve.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Not if he reuses the external engine parts it is. Meaning vortec block with TBI setup. I have that in a 90 c2500.
GM crate engines are the way to go, otherwise have yours rebuilt or keep an eye out for a good used one. I recently bought a 90K TBI 350, for 200 bucks (I think that's how much).
No. Vortec heads have a different bolt pattern for the intake manifold, so the stock intake will not bolt on. Also, Vortec heads do not have an exhaust crossover, which is why the EGR will not work unless you rig some parts up. If you did not have to deal with these issues, then you don't have a Vortec motor ('96-'00).
Hard
