Rear Bumper for 1980
JD_
Kansas
Will a stock rear steel bumper from a 1978 GMC fit on my 1980 Chevy? Both are 3/4 ton, 4x4, 350, 8' bed. My 1980 has no brackets or bumper.
Thanks,
JD
79K10
Sacramento,ca
Ryan
350/th350
it should, if not it shouldnt be too hard to fab up a bracket
Looks like the brackets changed in '81 so you should be good. :)
JD_
Kansas
Great! Thank you for the responses.
I'm buying the bumper and brackets from a salvage yard. Anyone have a diagram of how the bumper bolts onto the frame?
Thanks,
JD
JD_
Kansas
Great, thanks.
JD
That 89sub sure is a helpful feller
J Knight
Baytown TX
82 Chevy
350ci
If the bumper is a step bumper, the brackets are fix/welded to the bumper so its an easy swap.
87R10_Cruising
