Random Diff Questions
eskimomann209
Modesto
Marcus
That’s fantastic.
This sets a standard for just how bad a gear can be setup and still “function”. Did it make noise before you opened it? Or did it wear is self in to the point it was actually silent?
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
No noises. I've driven it around the yard but haven't gone highway speed yet. I bought the truck and trailered it home. I finished the engine swap and now I'm going through and doing the little maintenance items before I put it on the road.
ali_c20
Austria
Alexander
C20, K5
Little maintenance often opens a can of worms...
at least his can of worms popped open in the driveway at home with a drain pan rather than an uncontrolled explosive device 80mph on the freeway 15 miles from home at night
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Everything I touch on this truck turns into a can of worms. I'm somewhere between a barrel of worms and an industrial scale nightcrawler farmer at this point.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Man, the person that worked on this truck before me was truly an axle savant. I have two more questions to add to the list.
Is this collar/washer just a part of the bad oil seal? Or is it a separate part I need to replace?
What is the procedure to seat the pinion nut? I must have cleaned off my marks I made before I took it apart.
The manual I'm looking at shows the initial setup procedure. It says to torque but until it takes 10 lb-in to set the bearing, then torque to 220 lb-ft, and check for 20-40 lb-in drag. I'm thinking a few ugga duggas with the impact and check for pinion slop and minimal drag. I don't have a beam style torque wrench handy.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I guess it would help if I uploaded the photos. I think the part is the "slinger" according to the diagram I found.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The slinger is just to help keep dirt and water away from the seal. If you can't beat that one back into shape Id replace it. But as long as it isn't loose on the yoke you can reuse it.
As far as the pinion preload, you can do it right with the proper tools and a new crush collar, or you can wing it with the old one. Lots of locktite and torque it up to 120 - 150 or so, without adding more crush and you may get lucky. I don't recommend it though.
dvdswan
Port Orchard, WA
Dave
I think that's why they have carriers for higher gears upto 3.50s and lower gears of 3.73s.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I just replaced the oil seal due to it leaking. I don't want to ram in the old, damaged slinger if I can help it.
1985Reese
