305 to 427
80sman
Franklin NH
Edward
Little over a year ago I bought a 84 K10 in Vermont. It originally had a 305, someone put a 307 in and I want to put a 427 in. Truck originally had a 700r4 and I put a TH400 in. I just want to make sure that the shift linkage is all compatible. I also read that one of the heads has a different exhaust flange angle. What does everyone use for long tube headers. Looking for a ceramic coated set. Will a set for a 454 bolt on and still have the clearance?
This is my first frame off resto and first time messing with a chevy
80sman
Franklin NH
Edward
Is the 427 a tall deck motor or a normal BBC? If its out of a kodiak or c60 its a tall deck. If that is the case normal 454 headers won't fit properly.
Im not sure, i attached some photos of it. It was my father's engine back when he used to race on dirt. I know nothing about it. I reached out to the engine builder to see if he can remember what it has for parts inside and he can't. Intake is from a marine appliance, has a reverse rotation firing order stamped on it
Beast496
Northern Nevada
Ron
GMC Sierra K3500
Do you know the cam specs? Might wanna figure that out before bolting it to the 400. don't wanna end up with too low, or too high of a stall speed in your converter. Being that you say it was a dirt track car, I'd assume it's probably built for higher rpms, instead of low rpm torque.
80sman
Franklin NH
Edward
Pic #2 appears to show a block casting number of 361959 which Mortec.com shows to be a 454.
It very well could be. That would make more sense. The internals are out of a race boat that had a 454. The block froze and cracked all the parts were put into this block ran again in the boat then taken out and had a standard rotation cam put in
80sman
Franklin NH
Edward
I don't. Thats why I reached out the engine builder that built this in the late 80 to early 90s, he can't remember. The engine would idle at 1k rpms so it it aggressive. Once its out of storage I'll pull the timing cover off and see what it says along with the oil pan to see what's in there
Turbo4whl
Downingtown, PA
Wayne
When rat engines are run in pairs in a boat, one rotates backwards so there is no prop wash. Since you stated a standard rotation cam is installed, the firing order on the manifold in wrong. Normal GM firing, 18436572.
Welcome to the forum!
We like pictures, so you did good. Engine picture, not a tall deck.
80sman
Franklin NH
Edward
You are correct. But this was a single engine application, its because it went through a Vdrive and to help the boat make shaper turns. Was in a gold cup race boat. Scotty-too G-27
That could be really cool. May be too radical for the street depending on the cam. Def curious to see what you find once you start digging
You can degree the cam with the engine assembled. Get a piston stop,mark true TDC on the balancer,degree the balancer or get a degree wheel. Pull 2 rockers off. 1 exhaust 1 intake. Use a dial indicator or calipers to see how much the pushrods move up and down. There is your cam lift. Now see when the intake pushrod starts and stops moving with the degree wheel,don't forget your .050 checking clearance. A little math and you know intake duration. Do the same for the exhaust. I'd roll the engine over,check a couple of rod bearing upper shells if they look good,I'd clean up the oil pump and make sure the relief valve is free. Do a leak down test if all that looks good,I'd run it. A bunch of people are going to say,oh be sure to buy a new oil pump. People used to check their oil pumps it was part of the repair procedure on a rebuild,I can get you specs if needed. Chevy pumps almost never fail,most common problem is stuck relief valves,and with the quality of new parts,I'd rather inspect and run a good used pump.
ss454elco
Pennsylvania
Rod
I converted from 350 to 454 in an 84 K10. I went with Hedman headers and they fit great. The linkage should work without any issues. The steering column won't have the same detents so the pointer won't line up with all the letters. You don't have a tall deck block. You can tell by the distance between the upper water pump mounting hole and the deck surface. A standard block will be about 5/16-3/8" while a tall deck will be about 3/4".
Dave83C10
Army
FL
Dave
Chevy C10
427s and 454s have the same bore but different cranks. The 396s and 427s use the same crank which is externally balanced while the 454s are internally balanced.
wonone
