question about front sway bar interchange
Blackbeard44
Washington State
andy
6.0 LS
Will a front sway bar from a 1985 K20 with a corporate 10 bolt interchange with a sway bar from a 1984 K30 with a dana 60?
I am picking up a dana 60 tommorow and the guy selling it needs to keep the sway bar from the truck that the D60 is getting removed from, I am not sure if the one on my truck will still work when I swap out the front diff, and if it is different any recommendations on where to buy a new one from?
nvrenuf
Mobile, Al.
They will interchange but you need the D60 unbolt plates. The only difference in sway bars is the diameter (effecting bushings) which I believe is a year thing.
awesome, thanks for the info, I am getting the plates with the front diff
i would get the brackets too, I dont know if the K30 mounting brackets where the bushings sit are any more difficult ot find than a k20 but i know some people said the sway bar brackets were the hard things to find not the other components. They bolt to the forward crossmemeber at least on my trucks.
Blackbeard44
Washington State
andy
6.0 LS
The guy selling the diff wants to keep the sway bar and frame mounts, but I am getting the diff, u bolts and the plates and all the steering parts including steering box
Ah, so you were wondering if your current sway bar on your K20 could be used iwth a D60 front, which with your current truck having one and the bolt plate being the only necessary item on that side of things, you can easily use your current u bolt plate and current stuff!?
nvrenuf
Mobile, Al.
I’m not sure if you are asking or answering but the ubolt plates for D44’s and 10 bolts (he has a K20) will not work on a D60.
i was wondering, but, then im now curious what he plans to do lol.
Wait, nvm, I see. Hes going to use the u bolt plate and diff, but keep his current sway bar / bushings / brackets that are on the truck.
Blackbeard44
Washington State
andy
6.0 LS
640 miles round trip, and I got the dana 60 i was searching for, but when I got there he would not budge and had changed his mind and needed to keep the U-bolts and the plate, but I was able to get the steering box.
now I need to find some u-bolts and top plates, any suggestions
Craig 85
Nashville, TN
454/TH-400/NP205
Sway bars are the same and so are the spring mount plates for a D60. I got my parts from ORD. Remember the D60 only uses 3 U-bolts and 2 studs. I also run ORD's sway bar disconnect.
Blackbeard44
Washington State
andy
6.0 LS
that is very nice looking, I like the sway bar disconnect, and I am relieved that the top plates will fit the D60, I almost walked away from buying it over not getting them, but I just didnt want to drive another 5 hours home empty handed
nvrenuf
Mobile, Al.
Ubolt plates absolutely do not interchange between a D60 and other axles.
Off Road Design sells some plate steel ubolt plates with a provision for the sway bar. Not only will these work but you’ll notice that the application is only D60’s, they offer different plates for smaller axles.
Blackbeard44
Washington State
andy
6.0 LS
I emailed off road design today and asked them if the plates interchange, they said they do not interchange, I am going to order a set of them tomorrow
that seems weird he wanted to keep the plates but was selling the axle lol
Blackbeard44
Washington State
andy
6.0 LS
the truck was a single rear wheel K30, and he had another set of axles that where dual rear wheel style he was going to install
