Pinion depth way off
Ryanbrown36
Ontario, Canada
Ryan
c1500
I put the oem .037 shim in and checked the pattern and this is what I got
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Looks like a decent pattern to me, right on the center of the tooth with feathered edges and no sharp lines... If I were to be super critical it may be slightly deep but hard to judge by a photograph.
Question, was the ring gear put under tension while you did the pattern?
I recommend you check pattern in three spots to ensure the ring gear is true and square on the carrier
If Backlash and TTR are good I would probably run it.
legopnuematic
Licensed Junk Dealer
MO
Spencer
You are in the ball park, a little shallow. What is the backlash at?
I agree with @CalSgt , check three places backlash/pattern and for runout. It’s a good practice and should reveal any discrepancies.
Still in setup bearings? I’d probably try about .003 more pinion shim, about .040, depending on what shims you have.
Ryanbrown36
Ontario, Canada
Ryan
c1500
Pinion was under tension, i torqued everything down before i ran it and backlash was .06” when i checked it multiple spots and times. The extra did wear off on two other spots on the ring gear if that would be helpful to you guys, or are you suggesting to re apply in a different spot and run again?
Ryanbrown36
Ontario, Canada
Ryan
c1500
Backlash is consistently .006” and yes still using setup bearings with all original shims that came off in the first place
CalSgt
CA
Casey
I was suggesting to apply and check pattern in 3 spots… We don’t need to see the other patterns, it’s just for you to ensure that the gear contact remains the same.
If you get a noticeably different pattern it’s indicative of a problem like a piece of garbage, bulge around one of the threaded holes or dent/ding interfering with the fit between the ring and carrier.
Just cheap insurance is all.
I don’t have the spec handy but is a good idea to check the pinion and total TTR but not until you have your new bearings installed.
Ryanbrown36
Ontario, Canada
Ryan
c1500
Okay I will definitely do that, appreciate the help
hack_man
MA
Tony
Wow after reading these posts I realize how lucky I was to get someone who knew what they were doing when they installed my 4:11 gears. It was a dealer back in the 80's.
I wonder how many mechanics still have this skill compared to back then.
duncan_schawalder
