- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
I can't believe you guys are actually talking about those old timey fiber filters?! Coming from the PCV valve, through the short curved hose, attaches to one of those antique fibrous filters inside the lower air cleaner housing with the metal clip thing that holds it up against the housing side!!
Come on guys! I can see keeping you all's trucks stock, but c'mon man! Gee ****. I was using those things way the heck back when I had my '64 Dodge dart in 1970! Take that thing and throw it in the trash! All that does is turn your air cleaner into a "oil bath type air cleaner". Me and maybe a couple of other guys on this site remember those things. I do. I had a vehicle that had a oil bath air cleaner on it, a '54 International Harvester long bed pickup! The only reason why I even knew what it was when I got that truck, was because I used to help my Uncle clean and change his out in his '53 Plymouth he had when he was in high school when I was a little kid, in the '50's! That's what you've got with that PVC filter!
I remember whenit came time to change the air cleaner there would be oil pooled all along the curved lower portion of the lower housing that had dripped out from that useless filter. Now you do have a oil bath filter because I look at the air cleaner and it would be soaked all along one side of the filter material. Thinking about how much oil must have entered the carb I'm bordering on having a diesel engine than a gasoline internal combustion engine!
So, get with the times guys, and think no wonder why you can't find those PCV filters is because NO ONE uses them anymore because they are relics of a bygone era! Get one of what I showed you, it'll even work on a TBI injection system. And another thing, you want a antique filter on a modern fuel injection system? C'MON!
i think this is an oil bath its a 2 ton truck lol
also, isnt the pcv filter simply a way to make the vapors being pushed from the crankcase dont just literally fill the oil filter with oil? Because its crankcase vapors. they are eventually gonna saturate, and being you dont want to make a vacuum leak for them(cant control that), you have them enter the top of the carb and just interupt the larger droplets so you don just straight up gum the system. if people replaced that filter and the air filter when needed more properly, that would prob not be so bad. plus, back then blow by and tolerances arent like today and the shift to those newer technologies is the shift from "okay, we fixed the problem, now lets refine it" but somehow we moved from that to going backwards with every damn car now has a complex PCV system with proprietary parts and they take a lot of work to change and they are not exactly cheap.
