Overheat AC issue
HUFFINCOSMOLINE
One Gas Station Town
N.
C-10
Sorry if this has been posted in the past, but would like others opinions about the issue at hand. So my 79 I converted over to a serpentine setup with a front belt system off of a 03 4.3 Silverado. Converted old AC compressor to the later model compressor. I have installed new 180 deg thermostat, radiator, water pump, etc. Truck runs and stays at 180 degrees with AC off. With AC on it’s getting up to around 220. Running late model fan. Should I buy dual electric fan setup? Really don’t like electric fans.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Are you running the correct water pump for the serpentine setup?
HUFFINCOSMOLINE
N.
C-10
I’m using this pump which is reverse rotation
Clean the condenser and put a pusher fan wired into the AC on it.
gmbellew
Kansas city
glen
suburban 1500
my tbi opens up the IAC when the AC is on to help with the increases engine load. might check on whatever comparable system you have?
^^^^ This also speeds up the mechanical fan. You might get buy with an idle kicker solenoid. But a pusher fan for the condenser wired into the AC was a common factory tactic for AC back in the 80s
jh86
united states
Jon
you shouldn’t need electric fans or anything fancy to keep it cool with a/c on. Do you have a shroud? What kind of fan are you running now? What radiator?
jh86
united states
Jon
I’ve never done the conversion described, but if you reverse rotation, do you need a reverse direction fan? Won’t the fan spin backwards? @HUFFINCOSMOLINE is the fan pulling air?
HUFFINCOSMOLINE
N.
C-10
Factory fan from the 4.3. My buddy has a new fan clutch he bought and didn’t use. So im gonna try replacing that first. Will update
NateP350
