What I understand is that I need an adapter like one of these:
GM OBD1 ECM MEM/CAL MEMCAL PROM Adapter with ZIF (Zero Insertion Force) socket Compare to Moates G1 Memory Adapter Allows you to use a custom programmed chip (not supplied) with your GM 66 pin MEM/CAL ECM. Note you will need to remove the cover to install this adapter however after that simply...
reddevilriver.com
boostednw.com
Couple of 27SF512 memory chips (or a compatible one)
https://allegro.pl/oferta/w27c512-pamiec-eprom-kasowalna-27c512-pdip28-13738377530
Plus a chip reader/writer
An ALDL 12 PIN cable like this:
The OBD2allinone pc scan tool to turn off the check engine light on OBD2 cars and trucks is made and sold by OBD Diagnostics Inc. Our automotive diagnostic tools can read and log any obd check engine code data.
obd2allinone.com
Has any of you tried playing with TBI and have comments on the above?
