Oil Leak Pissing Me Off
******* oil leak is back, I'm about to burn the truck to the ground. I'm going to take it to a friends shop and put it up on the lift, and see if we can find the problem.
J Knight
Baytown TX
82 Chevy
350ci
Ill tell you how Im going to fix my oil leaks, Im pulling motor and trans out, tearing them apart, all new gaskets, paint, and maybe a little chrome. Gunna TKO my damn leak!:boxing:
davbell22602
Bunker Hill, WV
I Dont
Have
One
I'm in the same boat.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Except for the part where you'll talk about doing it for 3 weeks, ignore everybodies advice, whine about how GM sucks and you're going to buy a Ford, and then post a new thread 3 weeks later about the exact same thing.
You lost me, bro
davbell22602
Bunker Hill, WV
I Dont
Have
One
What heck are you talking about on 3 weeks later part? I only have access to shop on every other week.
rainyraven
wilhoit az
Ben
k10 cheyenne
ok most likely this is not your oil leak.. but I had put a new motor in my truck and replaced all gaskets... truck would get warm and going down the high way it would leak making a huge effing mess, then it would stop.. long story short I forgot to put a bolt in the hole right there where the fuel pump goes.. in the front of the block there is a hole.. it goes all the way through maybe I'm the only guy who had to learn that the hard way I never noticed because the hole never left much trace of it being the problem.. sounds stupid on paper :( anyway it was driving me nuts and I almost took the motor out! I had dropped the oil pan twice timing cover twice.. anyway make sure there is a bolt in there!
Make sure the bolt that gets installed in that hole is a short one. That hole goes straight through to the fuel pump push rod, it's used during fuel pump installation. You thread in a long bolt to hold the rod in place while you bolt the fuel pump to the block. Then remove that long bolt and install a short bolt to plug the hole.
That hole is not there on many later blocks that originally had FI.
If I had hair......I would be pulling it out. I checked my oil, due to the oil leak, and I now have water in the oil, not a lot, when I took the breather off to add oil I noticed the whitish looking crap on the breather. I'm thinking when I replaced the intake manifold gasket a few days ago, one of the water jackets didn't seat like it should. I don't think it is a blown head gasket, because I don't have bubbles in the radiator. Anybody want to buy a cheap truck......a truck cheap. LOL does anyone have any suggestions?
Ben that's a damn good call, but my problem is my pan is dry, my leak is somewhere on the backside of the motor.
When my head cracked i didn't get water in my oil, only out the exhaust, so hopefully that is better news for ya.
If ya want you can drop the truck off in my driveway :waytogo:
80sman
