Knocking/ticking noise after oil pan gasket
cadillac_al
Maine
Alan
Well, even though the engine didn't start, it sure sounds like a real bearing knock to me. If it is super loud while running and nobody can tell where it is coming from, that doesn't sound good. This should not have happened by just replacing the rear main seal but I'm afraid something went wrong somewhere. If it was me I think I would bite the bullet and pull the engine and inspect the crank very carefully and plastigauge all the bearings. ( I don't own mics so I plastigauge). Then I would put all new bearings in it and hope for the best. I would also inspect the flexplate very carefully for cracks too. This would be a good time to replace it since they are pretty cheap. Maybe after all that you will figure out what went wrong.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Remove the oil filter, cut it open. Use tin snips, don’t use a hacksaw.
Once the filter is cut apart, remove the filter media. Spread it open, look for metallic debris. If the filter is clean, you can be reasonably sure your engine noise isn’t bearing related.
Sad Sack
Nebraska
Goober
C15
I know this is a silly question but if you remove the flex plate cover does noise still exist?
Mango
JacksonWyoming
Gil
Loose Flex Plate ?
Elvis has left the building!
CubsFan79
