Oil consumption?
The Right side of Washington
My 1989 big block has variable oil consumption too - sometimes a little, sometimes none, sometimes more than I expected. I just check the fluids every time I fill up and tell people it identifies as British....
Good description. Lol
JBswth
Vallejo, California
James
C25
292 cubic inches
Does anyone know what the average/acceptable oil consumption might be for a 5.0L "H" series engine with 65k miles? When I started work on this original and stock truck (52.4K), a compression check showed #1 @ 175 and the remaining cylinders @ 180-190 psi. A small amount of soot accumulates in the tail pipe but there is never any visible smoke on startup or while driving, even when I open the secondaries. Early on, I replaced all sixteen valve guide seals. It currently uses about a quart between oil changes every 3-3.5k miles.The truck runs and shifts GREAT! However, there is quite a bit of wear on the right side of the brake pedal.
Until the 90s, a quart consumed every 1,000 miles was considered acceptable. Anything less than that was considered outstanding oil economy.
J. B.
JBswth
Vallejo, California
James
C25
292 cubic inches
Looks like more brake pedal wear than expected for 50,000mi.
Whether it’s 50k or 150k, your compression looks high. I’d think it’d be closer to 125-135 psi.
180psi is L88 type numbers (12.5:1 CR).
Burning a quart between 3000mi OCIs isn’t terrible, but it’s not great either.
Before the 90s, a quart consumed every 1,000 miles was considered acceptable. Every 3,000 miles was considered outstanding.
J. B.
staco
kenaston sk
joe
vandura 3500
If it’s a quart low when you go to change oil is fine but if you added a quart and then it is a quart low again when you’re changing that’s excessive
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
It all depends on how much is on the ground???
Trucksareforwork
Spartanburg SC
Geoff
I have an H motor in my 85. It has probably 90k on it and zero leaks, and I changed the valve seals a couple years ago. It probably burns a quart every 3k.
I consider this good performance. :)
Nborden88
