JamesSam
- Feb 15, 2023
- VA
- Sam
- Silverado V10
- 5.7 L 350 v8
My oil pressure gauge has been doing some funny stuff. Specifically maxing out beyond 60 psi, like the sending unit is bad or disconnected, when coming to a stop, after a trip, and just before shutting off.
While driving it perks up to between 40-50 psi, which is perfectly fine with me. When I first noticed this happening recently I checked the oil and it was a bit shy so I added a half a quart, and it is still acting up.
My thoughts are I need to get under the truck and likely will need to wipe away some excess oil and check the connection on the sending unit. Maybe the sending unit is fading out? I replaced it about a year, maybe two years ago.
I have driven the truck to work and run errands today so waiting for it to cool and plan to check the oil level again.
So, has anyone here had this particular oil pressure guage experience? I know the 80's factory gauge for oil pressure is not as exact as most after market ones these days, but it does give me a sense of normalcy to see it read in the acceptable range.
