O2 sensor question
ChuckN
Bellinham, WA
Chad
On my AFR gauge that I received for Christmas, the connector for the O2 sensor is HUGE. I’m fairly certain there’s no way to fit it through any of the existing holes in the firewall, and I’ll be damned if I’m drilling one that size.
Does anyone know if affects accuracy on an O2 sensor to cut the wires and then resplice them together?
Thanks in advance.
Chad
legopnuematic
Licensed Junk Dealer
MO
Spencer
Does it have a plug/connector at the gauge?
On the ones I have I run the connector to the gauge from the outside of the firewall to the inside. Instead of the plug at the sensor from the inside out.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Does it use a bosch o2 sensor?
If so, you can snip the end off and put another end on with this.
As an Amazon Associate we earn from qualifying purchases.
fast 99
Spokane, Washington
With the proper release tool wires can be removed from connector and re-installed. It's a common repair procedure for bad connections.
ChuckN
Bellinham, WA
Chad
Thanks guys! Sounds like pulling the pins and reinstalling them as the easiest way, the connector goes right to the control box and does not go to the gauge itself.
I have an Innovate AFR gauge, and the “control box” mounts on a frame rail under my truck - supposed to be weatherproof. From there I ran the wires up to the gauge and soldered them inline.
Important tip. Find a good solid ground point, and make sure all gauge and wiring grounds to that point. The O2 sensor monitors very small changes in voltage, so everything needs a common ground.
ChuckN
Bellinham, WA
Chad
Yeah, good call. Sounds like we have a similar setup- mine is also Innovate. I was going to mount the control box inside the cab- if I remember right, the instructions for the LC-2 said that it needs to be protected from weather. So since it’s going to be close to the fusebox, I was going to use the main ground cleat on the e-brake.
My gauge uses the LC-1, and the instructions tell you to mount it under the vehicle near the O2 sensor. The LC-2 is part of a different Innovate product, and it has a different installation requirement. I know the LC-2 is newer and has more features.
ChuckN
Bellinham, WA
Chad
Hey bud,
I bought a de-pin tool kit. But for the life of me, I don’t know how to go about it- one end looks like it would still be way too big to fit through the firewall even if I pulled the wires out since the wires after the connector are molded into the wire.
Unless you can pull the wires out of the O2 sensor which would seem to be the answer- but I can’t seem to figure out how/ if the wires come out of the plug on this side.
Any thoughts? I’m a total beginner at this and will likely be trying to find a YT video if no one has any idea.
ChuckN
Bellinham, WA
Chad
Well, can’t take the wires out of the O2 sensor connector since there is a calibrated resistor in there that will mess it up. Ho-hum.
You might give Innovate a call and see if they have a suggestion. Making a hole big enough to fit that O2 sensor connector through is possible, but then you need to find a grommet that will close around the wire and seal the hole. Seems like there must be an easier method.
Turbo4whl
Downingtown, PA
Wayne
The wires would be released from the back of that connector. So the rubber was molded after the connector was assembled.
Use a hole that is there. Ideas, remove the fuse block connector from the fire wall, it is behind the fuse block. File a small notch for the cable to be next to the fuse block.
Or, maybe remove the steering column parts where it goes through the fire wall, put the plug through that hole.
Last idea, bite the bullet and drill a hole. Find a rubber grommet first so it fits the hole you make.
ChuckN
Bellinham, WA
Chad
Thanks For that. I got to thinking, and went out to the garage. In my minds eye, the extension wire from the control module was going to be inside the vehicle, but looking at where I want the O2 sensor, that won’t reach. So, that extension will have to be out of the vehicle at least partially. The small end of the extension wire that connects to the control module has a much smaller plug on it- small enough that I think I can fit it through at the speedometer grommet. Think I’m back in business- thanks for letting me think this out with y’all. Goes in Tuesday to have the bung welded into the exhaust.
Stickman
