teach
- Mar 1, 2025
- Virginia
- John
- C10
Want to make sure I don’t burn anything down here: I’m getting a 100 amp alternator (Powermaster, self-exciting) to replace my ac delco 63 amp. Currently, the bat wire goes from the back of the alternator to the starter (8-10 gauge I think… maaaaaybe 12?). I also have a fusible link at the starter and another at the firewall junction block. 4 gauge wire from positive battery to starter, 4g from negative battery to alternator bracket with a like 12 gauge wire that goes over to the interior body panel.
My question is about what I need to rewire. What wires are sufficient, what are too small? Only running single electric fan, halogen bulbs, and moderate radio/amplifier setup. Mechanical fuel pump, HEI, etc, so no other big loads. I’ve seen so many different options/explanations.
Here’s what I THINK I need to do:
Upgrade alternator battery wire to 4 gauge out the back —> 200/175/150amp fuse —> starter battery post. Do I need to replace the fusible links, too? Or is this plan sufficient? Thanks in advance!
