NP203 Transfer case backyard install
Big red square
El Paso
Lewis
I'm trying to install my np203 transfer case with a floor jack on a truck with 6" lift and 35's
Any suggestions?
Strick
Dunn, NC
Harold
C20 Crew
Any suggestions?
Bolt the case to the crossmember(s) and get some long bolts (3/8 starter bolts are great). The crossmember will help to sturdy the case and you can use it for leverage when trying to get the case aligned with the transmission. When you get the crossmember a few inches from the frame you can put the longer bolts through the frame and help support the awkward weighted case. I have done this a few times as well as pulling the floor out and using an engine hoist to install the trans/case combo. Good luck!
HS
Big red square
El Paso
Lewis
HS
Little confused what holes on the T-case will bolt to the crossmember?
My cross member only bolts to the frame and transmission.
fast 99
Spokane, Washington
Think the suggestion is bolt the TC to mount then mount to crossmember, then use a jack to lift the assembly up.
Big red square
El Paso
Lewis
The t case doesn't have a mount on my truck it just bolts to the transmission
fast 99
Spokane, Washington
My trucks are newer. Both are like that, neither have mounts. Was assuming he knew the application. I call a friend and just manhandle them in. They are awkward as heck. Someone probably makes jack adapters but never used one.
Big red square
El Paso
Lewis
I'm thinking about buying this jack(Dont want to)
But i would still need blocks since its so high.
fast 99
Spokane, Washington
How would the TC attach to it? Doubt that would help.
Big red square
El Paso
Lewis
that strap would hold it down also bigger area for it to lay on flat with out it moving back and forth.
SquareRoot
This was my suggestion. I have that jack and it is worth its weight in gold. However, I still had to use pieces of 2x4 blocks to get it high enough and that's on my K20 with 2" lift and 31 inch tires.
Big red square
El Paso
Lewis
Ok you convinced me ill be buying it.
SquareRoot
Strick
Dunn, NC
Harold
C20 Crew
My fault. The adapter bolts to the trans on an NP203. NP205 is opposite.
mick84
