No Running Lights!
chengny
Sorry...
$3.81
Specifications:
•Delphi pn: 12089188
•UM: 25 Piece Bag
•Gender: Female
•Material: Tin Brass / Plated
•Wire Range: 20-18
•Operating Temperature: -40°C to + 125°C
•Max Amp Range: 20 Amps
$3.81
3.73 Specifications:
•Delphi pn: 12089040
•UM: 25 Piece Bag
•Gender: Male
•Wire Range: 20-18
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Haha I'll just go cut one off a junker
chengny
Why don't you just strip, solder and heat shrink the leads where the plug formerly made the connection. It will be a proper, long lasting repair.
Those harness plugs are just used to provide flexiblity across the different model lines during the production stage.
I mean, really when you think about it, how often do you get the urge to go under the truck and unplug your rear lighting harness?
If you still feel you need to have the option to disco the rear lighting clusters, use bullet splices (with heat shrink tubing) instead of soldering.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I'm thinking about that. Id have to splice in the tow harness then
chengny
When you solder the various leads (parking,brake, back-up and directional) add an extra lead to each one on the "downstream" side.
Make those extra leads 4-5 feet long and when you go to wire your trailer harness you'll already have feeds that are in parallel with the main lighting circuits. Tack on the trailer connector, plug in and you're done.
It will be a far more professional looking job than those crappy squeeze-on splices that basically cut into the wire.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
temporary fix till spring time hahaha. I can't feel my hands. Its 8 degrees here
John81287
Mchenry,IL
V20
It'll do for now let me know if you want the plug off the c30
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Ya. Whenever it gets warm haha
Good job taking the time to find the problem and fixing it in those conditions man. :High 5:
Hobbbs
Kansas
Troy
C10 Silverado
This is the closest to my issue I have a 84 Chevy Silverado C10 longbed and I don't have low beams they won't turn on with he runnin lights like they're supposed to I havent dug into the wiring but the guy that had the truck before me did not know what he was doing and under the dash is a rats nest of wiring I took a test light to the connectors on the back of the lights and they aren't getting power but the dimmer switch is getting power I suck at wiring so I have no idea what is happening
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
You should start your own thread so that it'll help others with your same issue AND you're more likely to get answers or help.
Zach99999
searcy
Zac
I'm having an issue where all my lights work every single one except for the taillights they dont work I have all the lights in the front work blinkers and headlights and running lights up front....but in the back all I have are brake and turn but no running light or side marker light in rear
Sent from my SM-A015V using Tapatalk
check the ground on the... driver.. side housing? One of the two sides has a little eye connector screwed into the bed. that ground can mess with functions
Mine has them on both sides.
Make sure you have 1157 bulbs and not 1156.
Side marker is a 194.
crpntr78
Missouri
E
Exactly the remedy. Mine had the same thing. New ground fixed it.
referrich
