new tires and wheel spacers need help
1low4x4
Nick
Im buying some 265/75/16's to replace my 245/75/16's.
Im also wantinh to add a 1" spacer to move wheels out a bit. We all know how wide these feder wells are and my wheels are skinny at 6.5".
Questions are, what bolt pattern are my hubs so i can buy the spacers and what spacer isngood to buy. I dont want cheap junk but i dont wanna pay out the ***** either.
Also im not liking my tire options. Id like a highway tread (no mt or at) with white letters, but they are limited at least ones that look good. Up top is a pic of the tires i have now, may end up going with them again only bigger. Bf goodrich commercial
highdesertrange
kalifornia
mike
k30
good spacers are pricey no doubt about it. but for this part you want the best there is no cheap way out. why don't you just put a little fatter tire on it. imo in the long run it would be much better. bfg's are good michelin's are good too. I believe your pattern is 8x6.5. if I were to use spacers this is a good company http://wheeladapter.com/index.php , there is another in Colorado but can't find their address at the moment. highdesertranger
Moderator
Bolt pattern is 8x6.5 but will one inch be enough to clear the wheel studs?
1low4x4
Nick
**** didnt think about that
Green79Scottsdale
G.R. - MI
Bob
I know it may be semantics, but you want adapters, not spacers. Adapters bolt to your hubs, and your wheels in turn bolt to the adapters. Spacers simply slip between the wheel and hubs, and I do not like that situation depending on the width of the spacer.
Some guys simply cut or grind their studs to clear the adapters. I would suggest getting your new tires first so you have a very accurate width of adapter to put the wheels/tires exactly were you want them.
Your situation is one reason why I never bought a set of those wheels. They don't push the tires out anymore than stock, and they almost look like they pull them in further than stock.
Good luck on your adventure.
farmerchris
southeast kansas
chris
ignore previous post,don't carry gm stuff.do have good products,lol
crowe-t
