speedy
- Mar 5, 2014
- MS
- Brandon
- C10
I havent installed the new stuff yet but i want to be sure i have all my parts before i attempt to install them. My previous setup was a stock aluminum intake with the egr deleted and a leaky wore out quadrajet with a broken choke. As long as I have owned my 82 it has never had a working choke. It wasn't even hooked up and I can not began to tell you where the wire is even at or where it should be. Is there a way I can rewire the choke with this new carb? What power source do I use?
Also with this new setup will I be able to use my existing throttle bracket?
