New 20's on the 85
70Chevelle
TX
Robert
c1500
Picked up a set of Vision Wheels, I ended up having to run a 1/2" spacer on the front to clear the hub which required tracking down longer wheel studs on a Saturday afternoon but I got it done.
255/45/20 out front and 275/45/20 in the rear.
Pretty happy with the look, need to fix the rake a bit by raising the back about an inch but it rides so much better than the old rims and dry rotted 275/40's
J Knight
Baytown TX
82 Chevy
350ci
Sharp!
i like it! :)
Mark L
Charlotte NC
Mark
1973 & 1986
250ci Inline 6 Baby! & Neck Snapping 305!
That looks great, how much have you lowered it?
74 Shortbed
Very nice..
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Nice look, but I've never been a fan of spacers due to the dangers using them. Most tire shops won't even work on vehicles with them installed due to liabilit . Spacers like to get loose, so make extra sure to torque and check often. Were you not able to find those wheels with the correct backspacing? You might want to look into installing some wheel adapters instead and replace the spacers for safety reasons. I'm just throwing it out there as a concern.
Qwk
Cincy
Craig
5.7/T56
Looks Good!!:cheers:
70Chevelle
TX
Robert
c1500
The spacers were not for offset issues, but rather for clearance issues on the wheel hub, part of the reason for this swap was to eliminate the wheel adapters that were on it. I didnt plan to or want to run spacers but at the end of the day it will be fine. It has new longer wheel studs and I check the lug nuts often.
70Chevelle
TX
Robert
c1500
It was lowered when I bought it, cut springs and a flip kit. I am going to do drop spindles and maybe 1 coil cut springs, its way too bouncy right now. Ideally I would like to raise it 1/2 inch in the front and an inch in the rear if I can.
Wracks81
TN
c10 scottsdale
truck looks nice.
