Howdy yall, I'm back again, I hope this gets some attention despite this thread being vacant for a couple months. I finally got a chance to work on the truck again and narrowed the issue to cylinder 8, all other cylinders are relatively clean but cylinder 8 is covered in oil residue. Thought it could be broken ring from cam wiping out so I popped the heads and oil pan and tapped out the piston. Piston rings look relatively fine and we're clocked correctly. Top ring gap for 8 was .024, a bit large but it went in at around .022. Cross hatch still looks good so I doubt the cylinder was glazed. Next up looking for the cause I popped out the old horoscope and checked the intake/ exhaust ports of the heads on the bench. 1,5, 6,8 all have varying from a bit of oil to a pool of oil sitting on top of the valve on the intake side. Cylinder 8 is the worst with oil and a ton of residue on the top of the intake valve.
To recap the issue I've been having is it would put out blue smoke at idle, just a bit and when revved would put out a big cloud of grayish smoke. With a PCV on the truck would put out almost no blue smoke at idle but still would put out a cloud when revved.
This is where I really need help. The machine shop I use is convinced I should pull the motor and have it rehoned. (The original shop that honed it they have found does some kinda shotty work) my question is does this sound like valve seals to you guys? I would hate to pull the motor just for it to be valve seals all along, I already popped off the heads with it in the truck just to discover this now.
I would greatly appreciate any help, machine shop thinks it could be cylinder 8 rings never seated because the engine has some blow by, but the blowby only started after the cam wiped and I don't see any glazing on the cylinder walls which I would assume would happen by now, the engine also made about 180 psi of compression cold on every cylinder. Thanks ahead of time, I look forward to hearing your ideas because I'm stumped
