Left hand threads on 14 bolt 9.5in Ring Gear?
jetman
Minnie, AK
Don
Have decided to take the plunge and upgrade my '83 k10 -> k20. Obtained a well used set of k20 axles, will upgrade the stock rear 14 bolt 9.5in open semi-floater with a posi before I install it. Never have done driveline work before, am a bit nervous. Read that the stock carrier holding 9.5 ring gear has left hand threads, can someone confirm or deny before I attack with my impact? Many thanks!
Moderator
Yeah, it's reverse thread. I had a brain fart one late night and ruined a perfectly good ring gear once.
jetman
Minnie, AK
Don
Many thanks for the good advice! Sorry to hear about your loss..
firebane
Calgary, AB
Curtis
Left handed threads are found in a lot of areas where it needs to counter the rotation of the object.
For example a table saw uses left handed threads to counter the rotation of the saw blade so the nut doesn't come loose.
Johns C10 Hubcap
