K5 Blazer repaint cap body color or white? How to remove fading paint on fiberglass.
@bucket it has a mostly smooth but textured finish. Here’s some closeups.
Looks like the original tan finish there for sure.
I'd really like to know how GM applied the original finish. I don't believe it was gel coat.
If I were gonna pull the trigger on painting it, I still think I'd go white but man, I've gotta admit it looks real good tan too!
ZIMM78Blazer
Tx
Previous, previous owner 20ish years ago painted the Doeskin tan cap white and some of it runs off when wet so I’d like to ideally remove what’s left of the white and restore the original color.
What can I use to remove the chalky spray paint and not harm the original tan underneath?
Tried pressure washer and a plastic bristle brush to no avail.
If I have to repaint it do y’all think I should go white or body color? Guessing they painted it white due to southwest heat coming right through the uninsulated fiberglass cap.
Where can I find WA8265 Doeskin tan that doesn’t cost $30 a can?
ZIMM78Blazer
Tx
You can use tintable Raptor coat to match the original texture with your color choice. Saw it on u tube 1 if the truck shows that use to bed one tv. Forget the name but it looked good.
ZIMM78Blazer
Tx
ZIMM78Blazer
Tx
Sorry for reposting ur stuff. Not very good with this stuff
Auburn, Washington
Overspray Ray (previous owner) had painted the door mirrors white so there is already some white I need to get off the doors but it’s pretty baked on and not too noticeable so leaving that for now. I might try one of those wipe on clear coats on the fiberglass cap. It would at least leave a gloss finish.
Please don’t. Just like your post about using some rattle can paint again. You just spent time correcting all the Overspray Ray issues.
Plus, you can’t sand the bad stuff off as you’ve found (because the surface is textured).
If you can’t finish it properly then better off to leave it as is, IMO
tinny
