Joys of the 10 bolt
RoryH19
Rory
R10 Silverado SWB
What happens when you change axle seals on a k5 10 bolt.
Drill, punch, hammer and some serious luck it came out.
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Why are those always broken!!!!!
The88
Mhmm
South Louisiana
ThatGuy
That was mine. Center pin had to be beaten and cut out.
ali_c20
Austria
Alexander
C20, K5
Rebuild 10 bolt and 12 bolt, both broken. I'm not sure if it was caused by the previous owner. He thought right torque is when the bolt squeals.
RoryH19
Rory
R10 Silverado SWB
I think the po over tightened the pin.
It also had a lot of scaring.
Definitely a common problem since it was in stock at the local parts store.
$4
75Monza
Colville, Washington
K30, K20, K20
Because of locktite usually present on bolts like this, I always have a map gas torch and heat up around bolt first, attempt to tighten it not till it moves, just till I reach torque, then back it out and at any point when it feels more resistance on removal, go back 2 threads or so after spraying some lube on threads you can see, then back out some more.
Moderator Administrator
That same technique I use for exhaust manifold bolts and studs. Patience pays off big in the end.
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
Guess I got lucky, you should buy a ticket!
What they need to do on these, it stop the lock tite and use anti seize instead. Then use a bend over tang to block the bolt from being able to spin. Problem solved.
BigDaddy72
Bentonville Arkansas
Travis
C30 Chassis Cab
Yep easy does it don’t be in a hurry and like others said heat and patients. They do snap of easy.
Sometimes a 3/8 impact turned down heat and just tap it back and forth gently the impact with some finesse will shock it loose. Steady pressure no heat and a cheater bar/barker bar will snap it nearly everytime.
Glad you got it out that’s the most important thing!
eskimomann209
Modesto
Marcus
Mine broke at some point and the last guy welded the pin in. Just a quick tack. I had no idea. Drove it for a few years till the weld gave out and the pin dropped into the pinion while I was taking off.
rgorma01
