I've developed a whine in a just 10 miles of driving
Gander
Army
Dirty Bay, TX
Lawrence
Could having too much ATF in a transfer case screw something up? I've drained like a quart from a fill plug (2nd time this happens, last time I've had to add like an ounce, so it's random) and since the ATF came out dark I've changed it. I suspect the darkness comes from the clutch material from the gearbox leaking into transfer case.
You’re leaking trans fluid through the T/Case adapter into the T/Case. Common problem. Simple enough fix, just a bit of a hassle to take the T/Case and adapter off to replace that seal.
mibars
Nadarzyn, Poland
Michal
Suburban V1500
Did you know that the whole bearing journal can break off the differential carrier and you can keep on driving? Because now I know! However it made it chip one teeth since the oil change maybe 100 miles ago
Anyway now with a Truetrac fitted it's not only quiet, but also no more one wheel peel especially in rain
duncan_schawalder
