Is this a TH350 & which flex plate???
Jordi
united kingdom
Daniel
I cannot find a serial number anywhere the manual says, most likely its all just too grimey and i’ve not cleaned it well enough.
One website says you can go off oil pan shape & bolt pattern which suggests its a TH350.
Before i order bits if anyone could confirm.
Thanks.
waterpirate
delaware
v10
5.7 tbi
That gm oil pan chart is the chit. Yes.
hey mister
North Coast
Marty
Yep, 350.
TransGo makes a fantastic shift kit for under $100.
On a scale of 0-10 with 10 being very difficult, I would say it's a 4 or 5.
  • Like
Reactions: WFO
Jordi
united kingdom
Daniel
Excellent, thanks chaps.
Next question then, is the 139 tooth flex plate the correct one?
It is a 6.2 diesel.
Jordi
united kingdom
Daniel
Yep, 350.
Is that just all the link arms & bushes?
hey mister
North Coast
Marty
No.
Gaskets, spool springs,
Plates and steel check balls instead of the rubber ones.
Even govenor springs and "O" ring.
And the instructions are very straight forward..
  • Like
Reactions: WFO
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
No.
Watch some YouTube videos. Get a small tub of Vasoline, put it in the fridge before starting the valve body install. You will use the vasoline to “glue” the check balls in place. DO NOT use wheel bearing grease, it won’t dissolve in ATF. Work slowly, cleanly, don’t force anything.
The biggest hassle is fighting gravity. Use the vasoline to hold things in position.
NickTransmissions
Las Vegas
Nick
Are you asking about transmission internals or suspension parts? Link arms and bushings would be suspension (control arms, their bushings, sway bar and links, etc).
If you're asking about transmission internals, at least those relevant to shift kits, you have the valve body, with valves, springs, plugs, an accumulator piston and spring for third gear, separator plate, gaskets and so forth.
Jordi
united kingdom
Daniel
I was thinking of the actual external mechanism. All the little rods that operate the gearbox.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
That's all I've got.
kfrdavid
