Is this a good pattern for gm 14 bolt ff?
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Is this a good pattern for a GM 14 bolt FF?
idrivea2002golf
San Diego
Spencer
Not sure yet.
The pinion looks to be too deep. Compare your first image to the bottom right of this screen shot:
Chevy 88
Canada
f7t6
GMC
This might not be of any help to you:
One time I backed into a driveway, and when I tried to back out, the rear end locked up.
Could not go forward or backwards. Rear diff was ******.
Stranded? Nope, I dropped her into 4 low - trans in first, and then it was peddle to the metal.
Ain't no ****** up diff is gonna hold me back! Truck went down the road just fine. Just had to turn up the radio a little.
Little bits of metal on the road were like bread crumbs behind my rig.
When I rolled the axle out from under my truck, the diff sounded like a coffee can full of nuts and bolts rattling around.
True story.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I agree, touch deep.
Add .004 shim to what you have right now and repattern. (Add in this scenario as the 14b ff uses a cartridge type pinion, if it were a say, 12 bolt, it would be remove shim)
What is your backlash? New gears correct?
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Okay thanks guys. Backlash is set at .006-.007 and this all gears and bearings.
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
How about this? Added a .010 shim as that was the smallest i could do.
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Sorry yes new gears and bearings
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
This is the pattern I just ran with .006 backlash and that is with putting a load on the ring gear for a good contact pattern.
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Just for context, I have a 1990 Chevy blazer with the stock V8 TBI350 700R4 trans and an NP 231 transfer case running 35 inch Tires. won’t be doing nothing crazy.
Supporting Member Army
Looks great to me. That's pretty much exactly what mine looked like when I rebuilt the rearend a few years ago. Factory 8600GVW K25 with 350/TH400/NP205, 4.10's, and 35's. I've towed and hunted in it for years since the rebuild and had zero issues. I added a grizzly locker at the same time as the rebuild.
hauto85
