Is the 1 Ton frame wider?
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
I tried to install a push bar on the C30 over the weekend and it would not fit. It was supposedly off of our era trucks, but it was about a half inch too narrow to fit over the frame ends. Is the 1 ton frame physically wider than the 1/2 and 3/4 ton frames?
MadOgre
NA
NA
NA
NA
NA
I know the body mounts are in the same spot. I would think the bumpers are the same fit from 1/2 to 1 ton as well.
marks86
Latham, NY
Mark
12v Cummins
the only difference between the two frames are the channels are wider on a 1ton under the cab area, I think its like 7" on a k10/k20 and 12" on a k30.... width wise should be the same
da_raabi
FloriDUH
Adam
c30
Bugger. I dunno what the hell is going on then. The seller said it was a 10 minute bolt on deal... I'll take some pics and post em up to see what y'all think.
marks86
Latham, NY
Mark
12v Cummins
10bucks its off some other truck
da_raabi
FloriDUH
Adam
c30
Is the Blazer frame any different? I know this guy used this thing on squares, I'm just trying to figure out how or what.
marks86
Latham, NY
Mark
12v Cummins
no they are the same just shorter
Scorpion
Denver, Co
Think 72 and older were slightly narrower. If you look up the differential pin/leaf spring centers for the squares on a 4x4 (73-87) you'll find 32" which is also the measurement from the center of one frame rail to the center of the other. Since bumpers are same same between 2x's and 4x's that holds true for your c30. Since bumper brackets attach to the frame rail mid-line, 32-inches would also be the same measurement of the bolt spacing (right to left) on the push bar you have as long as the mounting brackets also mount midline of each frame rail (as mine do on my '74).
If the measurement isn't 32-inches center to center, it's not the right one.
da_raabi
FloriDUH
Adam
c30
I'll measure it when I get out there this afternoon. I'm kinda pissed about this because I thought it was going to be a nice easy project. So much for that idea...
marks86
Latham, NY
Mark
12v Cummins
it never is man.. it never is
If I had a dollar for every time I said that to myself LOL
chengny
It does not seem like the dimension you are looking for is included, but for reference - these are the frame dimensions for C/K 10, 20, 30 (& up to 70). They are all the same except where noted:
And, in case you're interested, body dimensions:
PBALLARD
plainfield,il
pete
k-30/ M1028A1
ACCIDENTS, they happen!! maybe the frame is slightly tweaked. Sometimes it is real hard to see without a tape and a straight edge
cartunesguy
