Intake manifold and stripped bolt
Turbo4whl
Downingtown, PA
Wayne
Whoa, he may want to get that bolt back out someday. I can’t see using Loctite in the first place on an intake bolt. Much less with primer.
Or if you meant for a helicoil, different story but a helicoil would be my last choice in this instance. Way more work than likely necessary.
My point, but probably misunderstood, is pipe dope (Teflon sealant) is not the best sealer for coolant.
Edelbrock
Earth
Grumba
K5 Blazer
Did you try and slightly longer bolt?
Damn dude, that is by far the best suggestion so far. Access the threads that are not stripped by using a longer bolt.
Genius!
You name must be Brett.
Genius!
And I made the same suggestion at the bottom of post #8.
Elderauto74
