Inline tube
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
Just a question , Has anyone used steel brake lines from Inline tube?? I got an order coming for new rear steel lines and they are pre-bent. Anyone ordered form them ?
Sad Sack
Omaha, NE
Goober
C15
Top notch product, I will never buy lines from anyone else if I can avoid it! Past experience was with pre-formed gas / brake lines on an F-Body and was completely satisfied with their product.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I’ve got their stainless steel hardliner and parking brake cables on my 79 C10 and their regular steel brake and fuel lines on my 71 Dart.
No complaints.
Rickf
Grafton NH
1974, 1954 & a 1937
The pre-bent lines can be tricky to fish thru/around cross members, prepare to have adult beverages on standby.
Yep, I did my rear line from the distribution block all the way back. Other than having to really cinch down on the joiner fitting more than I wanted, it was top notch. Don't be surprised if it comes rolled up in a box, just carefully straighten it out (so you don't kink it) and it'll be fine.
ChuckN
Bellinham, WA
Chad
This. I ordered up trans cooler lines for mine but gave up on them since trying to get them through around the engine was impossible. They were high quality tho.
Beast496
Northern Nevada
Ron
Sierra K3500
Same company I used, although I went from rear drums to rear disc, so I had to cut them back, weld tabs, and run rubber hoses up to the calipers. they are quality lines for sure.
jroacg
