Hydro clutch return spring.
Donkeyman
Caney Kansas
Greg
OK I have an 87 R20. I swapped out the 400 turbo for an sm465 4 speed. I had all the correct pieces from a donor truck. Swapped out the pedals but I don't remember exactly how the clutch return spring hooks up on the clutch pedal. This is the little round sucker that lives on the rod that runs through both the clutch and brake pedals. Does anyone have a pic of the spring in place or a diagram ? Only thing holding me back. Thanks.
ajd89
Central Michigan
andrew
If thats not a good enough or not what your looking for just ask ill take another
Donkeyman
Caney Kansas
Greg
Thanks AJD89. My spring is not as tight as yours. There are 2 notches on the pedal. My spring does not want to stay in the same notch in as your picture. Consequently the tension on the pedal is too weak. Guess I will try to find a new spring.
Fri00
PA
Shaun
N/A
I know this is resurrecting an old thread but did you ever find a replacement spring? Or does anyone have a source?
bigrich
