Steppin Razor
- Apr 21, 2023
- Houston
- S
- C10 silverado
Hi all. Does anyone know the caster specs for a 77 C10? I replaced my upper control arms and I'm trying to get a baseline setting. I did my tie rods previously and two alignment shops told me they won't do the caster/camber for less than $150 and that they'd have to order shims. I had one do the toe and give me the numbers for caster as it sat, then did the upper control arms. I found a video that suggested a 1/8" was just a touch less than a degree, but I don't know what the starting caster is with no shims and what number I'm looking for. I had negative caster according to the alignment shop, so I know I needed to change what was in there. The video was for a car, maybe camaro (hard to tell because the video was shot too close) so I don't know if my baseline is the same as his (which appeared to be 7degrees positive).
So anyone know the numbers baseline (no shims) and what the specs are? TIA
