Ran the self tappers in the bottom mounts. I'll probably go back and bolt it as well for good measure. Self tapper on the top driver's side and had to use some of the provided strapping for the pass side. For the bolt just to the left of the latch in the pic below, I used 3 drill bits, stepping up size each time. I had ~2" or so from the back of that latch mount to the condenser so I was trying to be super careful. First two went fine, the last one grabbed hard and went straight into the condenser
I pulled it back out and looked, didn't hear any hissing or see anything coming out. IT WENT IN JUST THE FINS!! I won't know if it nicked any of the tubes till I start using it and it builds pressure but I think I lucked out!
Then massaged the stock hardlines very carefully by hand to get them to play nice in their new locations.
Dusted on some black
Added some hose to protect the hard lines from rubbing on the core support
Relocated the ambient air temp sensor
Then cut the air diverter to clear the new line locations and reinstalled
