Help
liam
Seatle Washington
Liam
k20
I recently got a new project that i got running today and when i went to move it the truck wouldn’t move but i dont know how that could be because it has had a remanufactured transmission put into it in 2016 and i already checked the fluid and topped it off any ideas
liam
Seatle Washington
Liam
k20
The engines on, theres a driveshaft and a rear axel and its not on a lift.
Chevy 88
Canada
f7t6
GMC
Does "park" work? If you put it in park and push and pull on the bumper, does the parking gear stop the vehicle in both directions?
1lejohn
texas
john
k-1500, 2500 HD
Did you seat the torque convertor all the way onto the transmission input shaft? Do you feel the transmission change when you select the different gears? More important what type of transmission is it? 700R, TH350,400?
Sad Sack
Nebraska
Goober
C15
Modulator line disconnected?
Trucksareforwork
Spartanburg SC
Geoff
No movement at all? Tried every gear setting?
Is the torque converter bolted to the flex plate???
liam
Seatle Washington
Liam
k20
It doesnt feel like it goes into gear and it rolls when in park
legopnuematic
Licensed Junk Dealer
MO
Spencer
What vehicle is this? 2wd or 4wd?
Sad Sack
Nebraska
Goober
C15
Someone correct me if I'm wrong, but couldn't he hook up a pressure gauge to see if the tranny is building up any pressure while running?
legopnuematic
MO
Spencer
You could.
Sad Sack
Nebraska
Goober
C15
And it rolls in park so that can only be a couple things.
Jeremy89
