Help
Trucksareforwork
Spartanburg SC
Geoff
Really dumb point, but it's possible if you were told a new tranny was dropped in: Is the linkage connected to the tranny? I could see a world where the tranny is in neutral and not connected to the linkage, though I think you'd feel that when shifting the column.
Sad Sack
Nebraska
Goober
C15
Not dumb. One question is, did it ever drive for OP or did OP buy it this way...
liam
Seatle Washington
Liam
k20
Its 2 wheel drive with a turbo 400 and you wont no what the heck this is but it has a dne2 which is basically overdrive for turbo 400
liam
Seatle Washington
Liam
k20
I don’t know if it ever moved it was parked right after they put a tranny in and i toad it home
liam
Seatle Washington
Liam
k20
It feels weird when you put it into park it kinda grinds or something
Sad Sack
Nebraska
Goober
C15
Ugh, I don't know maybe a bad park pawl. Others will need to chime in.
Sad Sack
Nebraska
Goober
C15
Drop the doohickey cover. Confirm TC and flywheel are bolted together, hopefully the front pump is engaged with TC, make darn sure the linkage isn't screwed up, get under the truck and look at the shift bracket on the tranny where linkage drops into, have someone engage the shifter. Does it engage all positions properly and smoothly, can also remove the linkage and move the lever manually to see how it shifts into the proper position. I know you said you topped it off but tranny has to be checked when warm for a proper reading. A pressure reading with a gauge would be helpful too.
"The TH400 (Turbo-Hydramatic 400) transmission typically holds:
6 quarts in the pan alone.
11 to 12 quarts total when completely dry, including the torque converter."
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Did you remove/disconnect the driveshaft before toading it? If you didn't, you damaged the tranny.
Edit: I purposely said toading instead of towing. Staying with the theme
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Drop the timing cover. Confirm TC and flywheel are bolted together, hopefully the front pump is engaged with TC, make darn sure the linkage isn't screwed up, get under the truck and look at the shift bracket on the tranny where linkage drops into, have someone engage the shifter. Does it engage all positions properly and smoothly, can also remove the linkage and move the lever manually to see how it shifts into the proper position. I know you said you topped it off but tranny has to be checked when warm for a proper reading. A pressure reading with a gauge would be helpful too.
Timing cover has nothing to do with the transmission, did you mean pan, or inspection cover?
Sad Sack
Nebraska
Goober
C15
Nice catch, you beat me to it @DoubleDingo ........your "old" is showing again @Sad Sack .....lol
Hahahahahahaha timing cover, hahahahahaha, Yup, I'm old. I meant the doohickey covering the flywheel / TC, there's a lot of names for that cover, and you guys rock!
Chevy 88
Canada
f7t6
GMC
And it rolls in park so that can only be a couple things.
Ya, that narrows it down big time. It should be easy to locate the problem now.
Assuming that your not missing any parts, maybe a broken axle, blown diff, damaged trans?
My guess is that it has something to do with the shift linage, either internally or externally of the trans.
Or what Dingo said - T-Case in neutral, that would do it.
Jeremy89
