Headliner !
maryland
Ricky
r10
ok so i have a 87 c10 i want to order a headliner it did not have one when i bought it. but it does have all the trim along the roof and windows. So when looking at headliners you can buy they have one for trucks that came stock with them or one for trucks that came with metal roof. How do i know what i had? !!! do they not have the trim around the roof if they didnt? I dont think that is the case but hopefully someone knows.
CSFJ
You probably need to check you RPO codes if they're still with your truck. That'll tell you if your truck was originally ordered with a headliner. From what I've read on this site so far, a lot of the trucks out there had the headliners removed when they started to sag. The backing for it is the hard part to come by now from my understanding. Everyone who knew how to recover them grabbed them up.
If you have all the trim/support components...you are way ahead of the game.
Get an OEM style headliner.
Just remove the trim. Also - IIRC - the A and B pillar moldings will need to come down. Remove the sunvisors (at the hinges) and dome light assembly.
Then, while a helper holds the new headliner in place, re-install the trim pieces. Use an awl to help locate the screw holes.
alwaysbroken
