Turbo4whl
- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
Flickering headlights, could also be the alternator.
I was around in 1985. I was still running boost!Could be the flux capacitor about to activate at precisely 91 mph thus sending him back to 1985?
And maybe surprisingly, available about everywhere auto parts are sold. I bought one at the local Vato Zone a few years ago when chasing an issue.Switch is a good place to start, $20 at LMC, just got one. Im replacing all the switches.
The headlights have several connections from the light switch tot he bulb.
Bad grounding can cause this also.
removing the bulk of the voltage running through the switch will extend its life. idk if you know this but LED headlamps can still take sufficiently large amounts of juice. old wiring and the incredibly long runs of the wires and tendancy for low voltage operation possible (higher amps when low) , etcIf the lights work for a short time then off and back on the most likely is the headlamp switch.
Instead of wasting time and effort to install relays why not just switch to LED headlamps? You will get more light output and they draw less current. LEDs do not dim with a change in voltage. As long as you are in the voltage operating range they will light up the same.
If you go with LED headlights make sure to buy DOT approved ones. The cheap Chinesium ones do not have a proper beam and you will piss off oncoming traffic and you will be seriously disappointed in them. Holley Retro brights have a nice pattern that really lights things up. Worth the money IMHO.
But the switch lasts 20-50 years avg running old incandescent lights and costs $20 and 5min to replace.removing the bulk of the voltage running through the switch will extend its life. idk if you know this but LED headlamps can still take sufficiently large amounts of juice. old wiring and the incredibly long runs of the wires and tendancy for low voltage operation possible (higher amps when low) , etc
i was naming off incidental benefits to doing so, because the relays lose 1 benefit (brighter) when in LED terms, but its still worthwhileBut the switch lasts 20-50 years avg running old incandescent lights and costs $20 and 5min to replace.
The reason(s) for any upgrades have little if anything to do with extending headlight switch life.
