Grounding question
Keith Seymore
Motor City
Keith Seymore
4.3L
More useless info, When ever you have a flow of electrons, they create a magnetic field. When ever you have a magnetic field, you have the potential to have a flow of electrons.
In the automotive world and scientific community this is what is known as "magic".
K
H2OnSnow
New Hampshire and Colorado
Rich
Blazer
RF radio interference is caused by things like, spark plugs, plug wires, coils and alternators to name a few. A braided ground strap does nothing to limit that.
Yeah, this is not completely so. There are two kinds of RF interference; radiated and conducted. A braided ground strap absolutely does reduce conducted EMI, and would do between little and nothing to reduce radiated EMI. In 197x GM would care very little about reducing EMI since the radio was the only unit impacted by that interference. Today, it is a potentially real issue for all of the computers. So why should we care if it is only messing with computers? LS swap anyone?
Turbo4whl
Downingtown, PA
Wayne
K
Yes, but for the Young bucks, The next question: What is the big difference between an old truck generator and a newer truck with an alternator? Yes an alternator makes AC current and a rectifier converts it to DC.
These are things if you learn, you can fix your own old parts instead of buying a rebuilt part that may or may not work.
Perry you need to wait before you tell the right answer, I want to hear what the kids know!
H2OnSnow
Rich
Blazer
BTW, why did early Corvettes have their plug wires contained in steel "boxes", while none of the other GM rides did the same?
The fiberglass body of the Vette didn't shield the radiated EMI. In a steel bodied car, the fenders, hood, firewall, core support/radiator did the shielding. The Corvette shields were to perform the function that the other rides got for free from the bodywork.
Sad Sack
Nebraska
Goober
C15
Well, I'm no 'lectrical wiz, I always was under the impression that generators actually charge, and todays alternators just maintain a state of charge, hence the reason for making sure the batt was fully charged before dropping in a new alternator so as not too over-work it and burn it out. Please shoot me down if I'm wrong in that assumption.
Turbo4whl
Downingtown, PA
Wayne
@Sad Sack I won't make you wait for the answer. The generator has field coils on the case. Current in these create a magnetic field across the armature, current is produced. The commutator where the brushes ride has many contacts. So as it spins you get a steady pulse of DC current.
The alternator has the field coil in the rotor. When it spins it induces magnetic field to the stator mounted to the outside of the case. Since the stator is "Y" wound, it makes AC current. As stated that AC current is chopped to DC by the rectifier.
u157777
