DatKat933
- May 22, 2026
- Bremerton, WA
- Anthony
- K10
- SBC 350
I'm sure everyone is tired of questions about grounds, so I will apologize now. I have a 79 K10 fleetside which I replaced the bed on and the donor bed also has a reproduced bedside on the drivers side. Since putting the new bed on, I have not been able to get my taillights to work and I believe it is a grounding issue. I am just hoping to get some clarification on a few things since where I have the truck stored, I do not have cell reception so I need to front load information. Wiring and electrical stuff is my weakest point in automotive knowledge.
The taillight to body ground is on the driver's side where I have the brand new bed side. The bedside is black, so I am assuming there is some kind of a primer or coating over the bare metal from the factory. Do I need to take a wire brush and scuff off some of the black to get to bare metal?
In doing research on here, I see alot of mention of body to frame grounding. Does this grounding need to be an actual grounding strap or could it just be bolting the bed to the frame using the stock carriage bolts? When I had the bed off, I painted the frame with POR15 to hopefully prevent rust. Could that be preventing the bed from grounding to the frame properly? (This was a last second thought I had as I typed this).
If it needs to be a grounding strap from the bed to the frame, do I use a self tapping screw to attach to a bed rail underneath then find a hole to bolt to on the frame?
Sorry again for all the questions. I am trying to learn and really struggle with electrical work. I appreciate any help I can get.
