Front axle for 77' 2wd
Beastmo
Sanford, Mi
Maurice
GMC Serria
5.3L LS
I have a 77' square body and it has 4wd lifted and I want make it a street rod so I will be lowering it and would like to know what would be a good front axle for it?
Moderator
Oh boy. Your first post here may stir up a ruckus, lol. But welcome anyways!
So you have a 4x4 and want to lower it and ditch the front drive axle? It's likely uncharted territory. You may want factory front springs and some form of aftermarket "drop" axle that is designed around a GM disc brake setup.
Zelph
Nevada
So you want to handicap a Blazer. I cannot contribute to this sacrilegious act. ✌️
You'll want to look at a gasser style straight axle. You'd probably be better off putting C10 front suspension under it.
Just find a C10 frame or front suspension setup someone is getting rid of. If you want to go low, can't use a 4wd axle or straight axle
Beastmo
Sanford, Mi
Maurice
GMC Serria
5.3L LS
I live in Michigan and I have a rust free classic and will never take it mudding or trail riding. My wife and i want to cruise with it.
Thank you for all the information
Beastmo
Sanford, Mi
Maurice
GMC Serria
5.3L LS
I don't want a low rider but like 12" off of the ground
Beastmo
Sanford, Mi
Maurice
GMC Serria
5.3L LS
I want it like stock height maybe a little lower but definitely not a low rider
If you just want stock height,why don't you just take the lift out with stock components? Matter of fact I'd bet you can find someone who wants a lift kit to swap piece for piece and perform the labor.
kfrdavid
